2
This discussion topic has been answered Discussion topic: Sky box startup issues
This message was authored by: Malcolm298
I have had my Sky box for a while now.
For a while now it disconnects when the microwave oven goes on. We had the surpressor on the microwave changed, but that did not help.  In the last week the Sky Q box is not starting up,  I have to unplug ever time to reset the box.  I have noticed that the viewer card is discoloured, so wondered if it was overheating?  I changed its position to enable more air around it, however, this has not improved the situation.
Re: Sky box startup issues
Browning around the chip is very common: it's not heat-related.
Could be, I would do 2 things:
  1. Work through the following online help flow - you should be able to organise an engineer visit: Fixing Sky Q equipment
  2. If you feel comfortable doing so, unplug the Q box completely and underneath is a fan exhaust that can get clogged up with dust over the years meaning it is less efficient - give it a good (but gentle) clean
