Discussion topic: Sky box not working
This message was authored by: Kim+Joy
Sky box not working
We had a power supply cut and mini box stopped working
Avatar for Kim+Joy
Re: Sky box not working
Still bot working
@Kim+Joy wrote:
Still bot working
Hi @Kim+Joy
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
