Discussion topic: Sky box not working
Message posted on 28 Apr 2024 05:21 PM
Sky box not working
Tv says no signal. All 4 green lights are on the back box. Tried unplugging and it sometimes comes back on but only lasts for about 5 mins and then goes off again
Message posted on 28 Apr 2024 05:28 PM
Re: Sky box not working
@Cathsturman wrote:
Tv says no signal.
@Cathsturman
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Message posted on 28 Apr 2024 06:15 PM
Hi, I have changed the HDMI cable and still got the same result, 'no input from current signal'. I have swapped to the other HDMi port and again same result. I then brought the tv from upstairs down and plugged in and again getting the same problem. So 2 tv and 2 HDMI cables both not getting a signal.
i unplugged the sky box and now it won't come back on, just the sky Q light pulsing blue for 20 minutes
Message posted on 28 Apr 2024 06:18 PM
Hi @Cathsturman
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
