Discussion topic: Sky box not working
This message was authored by: J88888888888888
Sky box not working
Help - switches on but says no signal
This message was authored by: Invisiblename
Re: Sky box not working
That suggests that the incorrect HDMI port is selected on your tv, or there is an issue with the HDMI cable from the Sky Q box
I am just another Sky customer!
@J88888888888888
No signal (usually from your TV) or no satellite signal?
Avatar for J88888888888888
 No Satellite signal
@J88888888888888
Any particular channels? Have you checked the connections on the cables are tight (not too tight)?
All channels seem to be done at the moment. I've tried tweaking the cables but it doesn't seem to be working
@J88888888888888
If there's nothing obvious outside like a neighbours had scaffolding erected it sounds like your dish is slightly out of alignment and you may need to arrange an engineer.
No probs. Are you able to arrange for a Sky engineer to come out?
@J88888888888888
We’re customers on here. This is predominantly a customer helps customer based forum and you aren’t addressing Sky Customer Services.
This link provides various help:
https://www.sky.com/help/home
After trying that, if your only option is to call Sky, click on ‘Need More Help’ after ensuring the correct flag (UK or ROI) is displayed in the bottom right corner which should lead you to either a 0333 UK or 0818 ROI number. Don’t forget if you have Sky Mobile or Sky Talk you can use the free 150 number to call.
