Discussion topic: Sky box not working. Have tried turning on and off won’t connect
Message posted on 04 Nov 2023 10:25 AM
Sky box not working code mr001
Message posted on 04 Nov 2023 10:28 AM
Re: Sky box not working. Have tried turning on and off won’t connect
Is this on the main Sky Q box or a mini box?
Looks like it has lost connectivity @Jon24
See if a reboot fixes it.
Message posted on 04 Nov 2023 11:19 AM
Mini box
Message posted on 04 Nov 2023 11:20 AM
Have already tried re booting 4 times same error
Message posted on 04 Nov 2023 11:21 AM
Have you tried rebooting the main box first, then when that's back up and running do the mini box.
Message posted on 04 Nov 2023 11:22 AM
Yes
Message posted on 04 Nov 2023 05:23 PM
None of these things helped - any ideas?
Message posted on 04 Nov 2023 05:32 PM
We have the same issue today, been fine until today and the mini box connects to the main box and then drops out
Message posted on 04 Nov 2023 05:58 PM
Have you carried out a Network reset on the mini box @Jon24
Message posted on 12 Dec 2023 12:37 PM
Alot of posts on this. I had the same problem yesterday after Sky help got me to factory reset my router (which wasnt needed).
Anyway, after battling to sort the MR001 issue with my mini boxes not connecting to the main box, I remembered that for them to connect using the MPS button, they have to connect to a 2.4Ghz Wifi channel. If your Sky Router is set to combine the 2.4 & 5Ghz band into one SSID, then you have to disable the 5 GHZ band first. You can then connect the mini boxes, by following the onscreen intrsuctions using the MPS button. When they are connected you can re-enable the 5Ghz channel on the router.
