Discussion topic: Sky box not responding
This message was authored by: Victor19
Message posted on 18 Aug 2026 05:13 PM
No response from remote upstairs box is working
Find out more
Message posted on 18 Aug 2026 09:07 PM
Re: Sky box not responding
Hi @Victor19
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
