Discussion topic: Sky box not responding
This message was authored by: SPFrampton
We have Sky in two rooms in our house: it's working in one but it won't come on in the other. We've tried rebooting everything, changing the batteries in the remote, doing the 1-3 & 7-9 on the remote too. No change - what next?
Re: Sky box not responding
Hi @SPFrampton
Assume this is a mini.
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
With the mini box on with green led try completly resetting your Bluetooth remote.
You must press the buttons in the correct to reset.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
