Discussion topic: Sky box not responding cant delete programes cant record programmes and tele screen goes blank
This message was authored by: Colin1705
Cant record or delete programs  screen goes blank and won't show the picture.
Avatar for Colin1705
Level 0 icon
Re: Sky box not responding cant delete programes cant record programmes and tele screen goes blank
Not yet received  a reply to my first message
@Colin1705 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: BillMcGill
Our Sky+ box does the same. Did you get it resolved?
OP had a Q box.  If you have a Sky+ then these are no longer supported by Sky.   (I believe they can only offer you a switch to Q)
