Discussion topic: Sky box not connecting to wifi
This message was authored by: vaunyh11
Hi. My sky q is not connecting to my internet. Internet is working fine for everything else. Tried resetting at least 5 times. Turned everything off. Still not connecting.
Re: Sky box not connecting to wifi
I have moved your thread to a more appropriate forum
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Hi @vaunyh11
