Discussion topic: Sky box not connecting to router
Message posted on 11 Dec 2025 04:31 PM
Our sky Q box is not connecting to our router
Message posted on 11 Dec 2025 05:21 PM
Re: Sky box not connecting to router
@Ann181 who is your broadband supplier if its Sky do you have a black or white router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 Dec 2025 05:27 PM
Hi @Ann181
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
