Discussion topic: Sky box issue
Message posted on 16 Feb 2025 01:11 PM
Sky box issue
I'm having recurring issue with my sky Q box. The Q is flashing blue and solid red standby button , it's happening regularly. Switching power off and on fixes it
Message posted on 16 Feb 2025 01:17 PM
Re: Sky box issue
Hi @Pamelakin
If the reset doesn't fix it you may need to replace your box.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
