03 Mar 2024 06:47 PM
My sky has bos has lost internet
03 Mar 2024 06:59 PM
Assume this is your main Q box?
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
