Discussion topic: My sky mini box is not connecting to the internet
Message posted on 03 Mar 2024 05:00 PM
I am having issues with my sky mini box keeps loosing internet signal and keeps freezing
Message posted on 03 Mar 2024 06:18 PM
Re: My sky mini box is not connecting to the internet
Hi @Glen661
Reboot the mini as above.
Message posted on 03 Mar 2024 06:23 PM
That's great. Thanks for the advice
