Discussion topic: Sky box fan 3 second intervals
Message posted on 05 Jul 2024 10:17 AM
Sky Q box. Fan keeps turning on and off every three seconds?
Message posted on 05 Jul 2024 10:57 AM
Re: Sky box fan 3 second intervals
Hi @Adam181056
Is the Q box totally enclosed or stacked with other devices?
They do need plenty of ventilation and can run quite warm especially in hot ambient conditions.
If this isn't the issue then try a Reset Settings in the Q box hidden menu.
Almost certainly hardware failure requiring a box swap-out. Remember to remove the viewing card before handing over the old box, and check for a separate power supply transformer in the packaging of the replacement.
Message posted on 05 Jul 2024 11:15 AM
Thank you really appreciate the feed back.@TimmyBGood
