Discussion topic: Additional Sky Mini Box cost
Message posted on 05 Jul 2024 11:57 AM
I have a multi screen plus one additional box and would like to order another mini box - appreciate that I have to pay £50, but is there a monthly subscription or will this be free as think that I am allowed up to 4 additional boxes - is that correct?
Any advce is appreciated
Message posted on 05 Jul 2024 12:02 PM
Re: Additional Sky Mini Box cost
Your current Multiscreen subscription will suffice. You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
HAPPY NEW YEAR
