Discussion topic: Sky box and remote
Message posted on 09 Nov 2023 07:51 PM
Sky box and remote
My sky Q box is not responding to the remote,can you help please
Message posted on 09 Nov 2023 07:53 PM
Re: Sky box and remote
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Nov 2023 07:54 PM
There is a green light on my sky box but no other light showing. It's not responding to remote
Can you help please 🥺
Message posted on 09 Nov 2023 07:58 PM - last edited: 09 Nov 2023 08:01 PM
Hi @Mavis1
First make sure that the TV set is switched on and is switched to the HDMI input to which the Q box is connected.
.Try completly resetting your Bluetooth remote.
