Discussion topic: Sky box and remote not working
Message posted on 11 Nov 2024 04:59 PM
All the Sky graphics are gone and are black. Plus the channel is stuck on BBC1.
So I don't have any sky error numbers or instructions to work from. The remote only works going from channel full screen to channel small TV in left corner with the rest of the frame black. I've tried pressing 1-3 and 7-9 to reset remote. Nothing works. Please help
Message posted on 11 Nov 2024 08:59 PM
Re: Sky box and remote not working
Hi @Cat52
To reset the remote you need to press the buttons in the correct order.
First reboot your Q
Then
