Discussion topic: Sky booster not connecting
Message posted on 16 Dec 2025 09:09 AM
My sky booster has green lights for WiFi but no light on for connected
Message posted on 16 Dec 2025 12:52 PM
Re: Sky booster not connecting
On Sky Broadband you can use the WiFi booster to connect to your router or your main Q box. That's provided it is a Sky Q WiFi booster. If you have the Sky max router the booster can only by connected to your main Q box.
If you main Q box is successfully connected to your Sky router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light on the booster should turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
If you are using the booster to connect a mini Box then you may need to carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
