Discussion topic: Sky a mini no audio
This message was authored by: Glyn20
Sky a mini no audio
My sky q mini has stopped giving audio at all. Tried resetting it tried resetting the tv changing audio output to normal instead of dolbly even though the tv supports it.
This message was authored by: xchrissyboix23
Re: Sky a mini no audio
Hello
have you tried plugging it into another tv or changing the HDMI cable to test it. It could possibly be an issue with the HDMI cable if you have tried that already i would recommend contacting customer services as if its a faulty mini box it may need replaced by an engineer
Please Note: I am just another customer not an employee
Sky Glass Gen 2 43” Volcanic Grey, Sky Live, x1 Sky Stream Puck, Sky Broadband Superfast (Part Fibre), Sky Max Hub (SR213), Sky Ultimate TV, Sky Cinema, Sky UHD & Dolby Atmos, Whole Home, Ad Skipping. Former Sky Q Customer
hi @Glyn20
May I suggest a full power down of your TV (unplug or switch off at mains)
We often find this restores sound for others
