Discussion topic: Sky a mini box
Message posted on 05 Feb 2025 06:40 PM
Sky a mini box
I have had a new router fitted and now my sky q mini disconnects from my sky q box every time I turn my tv off which has the mini box connected
Message posted on 05 Feb 2025 08:04 PM
Re: Sky a mini box
Hi @Coleman3
Reboot the mini as above.
