6
This discussion topic has been answered Discussion topic: Sky a box and remote problem
This message was authored by: Saints7man
Tv will not turn off using remote. Have reset a box and remote several times. Changed batteries. No better .. after pressing turn off sequence I hear the click and tv comes back on. Any ideas? Do I need to replace remote.
Re: Sky a box and remote problem
@Saints7man wrote:
Yes it is a Sony. Was told by Sky guy to hold on/off button release then hold dow for count of three, this now longer works.
Hi @Saints7man
There is no need to press the Standby button twice..
Provided you have Smart standby mode in Settings - Preferences set to On then the Q box will switch off with the television.  So to put both television and Q box into standby it's only necessary to switch off the television with a long press on a correctly paired Q remote control.
You need to experiment with the duration of your long press. I find here with my Sony that about 3 seconds works without being long enough to restart the Television.
Hi @Saints7man   Only hold down the Sky Q remote power button until you see the led flash. This indicates the comand has been sent.
Avatar for Saints7man
If I wait for light then TV comes back on?
Hi @Saints7man
It's not a Sony TV by any chance is it ??
Holding the Power off standby for longer than 3 seconds will cause the TV to restart.
Try about 2.5 secs or so.
Hi @Saints7man
Thanks I will check it out and try.
Answered - Go to Answer
