Discussion topic: Sky Witness freezing
This message was authored by: fredq
When watching recordings of Sky Witness programmes, particukarly the "Chicago" trilogy for no particular reason the programmes lock up and stay frozen. The only way to get out of the freeze is to reset the Q box. This seems to happen regularly with recordings but not with streamings, is it my box or is it the programmes themselves. It is now happening often and is so annoying.. Any ideas what the fault is. I think it is my box  but strange it only seems to happen on Witness.
Re: Sky Witness freezing
Hi @fredq
When you say "reset the Q box"
Is this a Reset Settings inthe hidden menu or just a reboot?
I suspect the latter and so
