Discussion topic: Sky UHD/HDR
Message posted on 31 Dec 2023 01:20 PM
Sky UHD/HDR
Hi All
Is tgere any reason why Sky don't use Dolby vision rather than HDR? The difference between the two are night and day.
Message posted on 31 Dec 2023 01:37 PM - last edited: 31 Dec 2023 01:38 PM
Re: Sky UHD/HDR
DolbyVision is HDR. Sky use HLG which is more suited to broadcast.
DV is licensable which may explain it.
Message posted on 31 Dec 2023 02:12 PM
Re: Sky UHD/HDR
@jamo172 wrote:
Hi All
I think SKY's version of HDR (HLG) was developed before DV became widespread - IIRC DV only started becoming mainstream after SKY Q HDR started. Many TVs did not orginally support DV - my previous TV only supported HDR 10 & HLG.
Also & possibly even more the reason is that SKY's version (HLG) was specifically designed (by the founders BBC & NHK) for live events
Switrching to now use DV would not be financially viable
Message posted on 31 Dec 2023 02:44 PM
Re: Sky UHD/HDR
@jamo172 wrote:The difference between the two are night and day.
...whilst DV is 'better' such a large difference would indicate there may be a configuration/setup issue.
