Discussion topic: Sky. TV Q Box
Message posted on 21 Mar 2025 09:12 AM
Sky. TV Q Box
My to box intermittently cuts out for a second or two. Sometimes this problem is absent but on other occasions it will appear frequently. Twice the box has locked, the green light stayed on but the screen went blank. The box then didn't respond to the remote control. I switched the plug off and then back on and the box then did respond, but the box returns to the intermittent cut out. Help!
Message posted on 21 Mar 2025 11:10 AM
Re: Sky. TV Q Box
Hi @Skytvbox
