Discussion topic: Sky Sports Racing Freezing On Sky Q
Message posted on 07 Oct 2026 02:15 PM
Sky Sports Racing picture freezes when watching . It's extremely annoying . This is using Sky Q. Surely you must know at SkycHQ . This needs fixing.
Message posted on 07 Oct 2026 02:54 PM
Re: Sky Sports Racing Freezing On Sky Q
@Markgunners wrote:Sky Sports Racing picture freezes when watching . It's extremely annoying . This is using Sky Q. Surely you must know at SkycHQ . This needs fixing.
As yours is the only post I've seen on the issue (I've just watched the last race and it was fine), it's more likely a local issue with your setup.
Can you explain what you mean by 'freezing' ?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 07 Oct 2026 03:15 PM
Hi it's been freezing on and off for about a week. You will watch a race and the picture freezes for around a second or two then comes back. My friend( also Sky Q) has exactly the same issue so it's not a set up issue and definitely a Sky issue. There are also other posts I have read with same issues with sky sports channels.
Message posted on 07 Oct 2026 04:12 PM
hi @Markgunners
It should be noted that SKY Sports Racing (along with the History HD channel) uses a European wide transponder which is weaker than the UK/Ireland specific transponders that most channels use
Thus this is one of the first channels to show any slight mis-alignement
How does the SKY History HD channel work for you (assuming you have the HD add on)
Although on another transponder , how does GB News work for you (it is on another weaker European transponder)
Message posted on 07 Oct 2026 05:37 PM
Hi
Both of those channels seem fine.
Thanks for the reply.
Mark
Message posted on 07 Oct 2026 06:08 PM
Sky Sports Racing HD UK Uses an UK Transponder...
Only the Irish version is on a EU Transponder.
Message posted on 07 Oct 2026 07:27 PM
I haven't noticed any issues with Sky Sports Racing.
If you're in the UK, when you have problems check France 24 (510), TJC (662), or S4C (134) as they are on the same frequency.
Message posted on 07 Oct 2026 07:31 PM
Hi
We just need Sky to fit it as it's becoming very annoying and especially as the service isn't cheap so one expects a quality service.
Its very on and off but that doesn't mean it's acceptable.
Be nice if Sky replied.
