3
This discussion topic has been answered Discussion topic: Sky Sports Not Showing
This message was authored by: PaulL2
Added Sky Sports to my account more than 48 hours ago but still not showing. Any help?
Re: Sky Sports Not Showing
Hi @PaulL2
Have you tried rebooting your Q box?
Hi @PaulL2
Avatar for PaulL2
Thanks, tried that and still not showing. Says I need to phone Sky but closed at moment!
Hi @PaulL2
Try a Reset Settings in the main Q box hidden menu.
