43
This discussion topic has been answered Discussion topic: Sky Sports + Freezing
This message was authored by: mjstokes85
Is there ANY way to stop Sky Sports + constantly freezing and stuttering and dropping to awful pixelated quality?! PLEASE someone help sort this issue out it's on every single football match every single time I use it!
This message was authored by: KevNewMedia Answer
Re: Sky Sports + Freezing
Posted by a Sky employee
Hi everyone,
Thank you for bringing this to our attention and for tagging us @nigea99 .
We're sorry for the inconvenience this issue is causing. We've raised it with our support teams, who are currently investigating. We'll share an update here as soon as we have more information.
To help keep everyone informed, I'm marking this post as the accepted answer so the latest updates are easy to find.
Kev
Community Manager
@mjstokes85
Are you referring to the main channel 404 content or matches that can appear via the red button? I'm watching Wolves v Stoke without a problem.
Deleted, beaten to it yet again! 🤣
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
hi @mjstokes85
Although it doesn't sound like a one off problem for you, it would help if you can specify  any specific games you are having problems with so we can check our feeds.
Do you have Netflix - if so can you go to the app and select the Left hand menu & then select Get Help  & then  Check your Network and let us know what Connection Speed it shows for you
Avatar for mjstokes85
Level 4 icon
The app, anything in the app just freezes all the time, I have Port Vale Crewe on and I am now 7 minutes behind live due to constant freezes.
Update: just been on live chat to sky, the old 1TB SKY Q boxes basically cannot handle the amount they are being asked to do with streaming so they are sending me a new 2TB UHD box, this is a known issue and all 1TB non UHD boxes will
suffer this issue they said.
Level 4 icon
Watching Port Vale v Crewe.
Netflix says speed is 80mb.
SKY Q box is wired with Ethernet and I have 150mb Sky Fibre.
@mjstokes85
I admit I haven't heard of this problem with the older non UHD boxes but it I do think it could well  be part of the issue.
They were really just designed for Satellite reception & downloads etc before apps took off
Many of us here do have 2TB boxes (or 1TB UHD) so do not have the same experience
Hopefully a 2TB will sort this out for you
BTW For a doorstep swap don't forget to take out your viewing card before handing your old box over
This message was authored by: apchelt
Same picture quality issues watching Barnet v Cheltenham. Mine does not freeze but the picture quality drops reguarly so that picture is very blurred. I have a 1TB non-UHD box too, but watch many other apps with no issue (BBC iPlayer, HBO, Disney, ITVx, Discovery).
I tried to check bandwidth via Netflix but could not get to left hand menu, only sign in or learn more options.
Level 4 icon
Apologies I am being sent a 1TB UHD box not a 2TB box, hopefully it will sort the issue! Never had any problems last season but they have ramped up what the sky sports + app does now and it is a lot more resource hungry than before.
Mine picture, as well as freezing keeps going very blurry, essentially low quality like you have with the Barnet match. Get on to live chat and ask for a new box.
@mjstokes85
The 1TB UHD boxes are as powerful as the latest 2TB UHD boxes (the only difference is the HDD size) so hopefully this will indeed cure your problems. - With the speed showing in Netflix as 80Mb it certainly does point to the box rather than connectivity
BTW although I don't watch football I did switch to the PortVale/Crewe Game for a few mins (which was during the break but still had a feed) and had no problems at all, which again points to a problem, potentially with your box
Do let us know how you get on with the new box
BTW @mjstokes85
Although I know it isn't the same due to screen size, but  if you have a Tablet or PC you may find you get a better experience without the stuttering using the SKY Sports app/website whilst you wait for the new box.
@mjstokes85
80Mb is more than enough for a HD stream (and even UHD) so I don't think the connection speed explains the problems. More likely a CPU bottleneck in the older boxes although this is the first time i've heard of Sky claiming older boxes don't work properly with certain apps, and with Sky customer service recent habbit of making up nonsense just to end the call it might not even be true.
@nigea99 wrote:
BTW @mjstokes85
 ...using the SKY Sports app/website ....
I have used the Sky Sport + app on an andoid tablet and phone. Is there a way to get the app via the website?
If so I would be very interested to know how, I could not find a way.
@apchelt wrote:
@nigea99 wrote:
BTW @mjstokes85
hi @apchelt
just goto the skysports.com website - it is available  via the website rather than an app these days
hi @nigea99 - thank you!
Mea cupla. I have found it now... football then watch. This is great news, as the Sky Sports + on my Sky Q box is virtally unwatchable.
Answered - Go to Answer
