Discussion topic: Sky Remote Code for Electriq TV - Alternative Brands
This message was authored by: Sean53669
Hi i have a new sky Q voice remote and need to programme it for my Electriq 58 Inch TV.
My old remote works to control the volume but I can't find a code that works when setting up my new remote.
I have also tried 'Other Brands' with no luck.
Can anyone suggest any other brands to try which might let me remote control my Electriq TV?
Re: Sky Remote Code for Electriq TV - Alternative Brands
@Sean53669 try the Vestel brand
Avatar for Sean53669
Hi thanks for the suggestion. I tried that and 'other brands'  but sadly neither worked.
@Sean53669 the only other suggestion would be a pain but that is to try every other brand that is listed you may find one that works
