Discussion topic: I reset settings and now the box isnt working
Message posted on 11 Aug 2024 10:29 AM
After netflix app not working i followed some advise to reset settings on my Q box. Now the sky box isnt working. Any tips?
Message posted on 11 Aug 2024 10:45 AM
Re: I reset settings and now the box isnt working
How is it not working @Jemmaski
Did you completely reset the Q remote?
Have you tried rebooting your Q box?
If you had to press the amber button on the Q box to bring it on then:-
Message posted on 11 Aug 2024 10:57 AM
I've got sky on now but the picture is in the corner and the rest is blue screen (like you're on the home page). The remote isn't responding and the 7&9 1&3 aren't doing anything but flashing red (no messaging on screen)
thanks
Message posted on 11 Aug 2024 11:01 AM
