Discussion topic: Sky Qbox keeps switching off
This message was authored by: Bahra+50
My sky q box keeps switching off any ideas on how to fix?
This message was authored by: ozsat
Re: Sky Qbox keeps switching off
Is it on an open well ventilated shelf?
It could be over-heating with the current hot temperatures.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Avatar for Bahra+50
Level 0 icon
It is an open well ventilated shelf, the box is also two years old. It happened last year too.
I called sky, and hey're sending me a new box
While you're waiting - check under the box to make sure the fan vent is clear.
@Bahra+50 If they are sending you a new box it will more than likely be a doorstep swap with DPD remember when doing this  TO REMOVE YOUR VIEWING CARD
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
