This discussion topic has been answered Discussion topic: Sky Q
Message posted on 06 Jul 2023 09:12 AM
I had the error message unable to connect to the satellite signal so I followed the instructions to reset but when I got to the part where it says to press the house nothing happens. I then checked the remote control as it said by pressing the ? And the red light came on so then I pressed ? and standby as the instructions said and still nothing. The tv will not reset I was without my internet for a whole week and now this has happened and I have no TV. I am disabled and suffer with mental health issues I live by myself I have no one to help me I can't get through to speak to someone please can someone help me
Message posted on 06 Jul 2023 12:50 PM - last edited: 06 Jul 2023 12:51 PM
@Liise wrote:
I've tried to but it keeps sending me round in circles
Hi @Liise
You need to check your LNB setting.
You do this in the hidden menu.
In Setup in the hidden menu you see LNB type.
Scroll right and you have the Option to set Wideband or SCR.
You need SCR
After changing the LNB type to SCR you need to reboot the Q box.
Message posted on 06 Jul 2023 09:21 AM
Re: Sky Q
Book an engineer by yourself from sky.com or the My Sky app.
Message posted on 06 Jul 2023 09:29 AM - last edited: 06 Jul 2023 09:31 AM
Re: Sky Q
Hi @Liise
Edit
If you carried out a Reset Settings this will have disconnected the remote from the Q box.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 06 Jul 2023 09:44 AM
Re: Sky Q
The remote is now working but the SkyQ still won't reset it's saying you need a satellite signal to watch this tv
Message posted on 06 Jul 2023 10:39 AM
Re: Sky Q
Message posted on 06 Jul 2023 12:42 PM
Re: Sky Q
Communal system but no one else has a problem
Message posted on 06 Jul 2023 12:43 PM
Re: Sky Q
Re: Sky Q
hi @Liise
In which case you may need to check/set the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down (switch off at mains or unplug) your SKY Q box and restart it for the change to come into effect
Hi @Liise
You need SCR
Message posted on 06 Jul 2023 01:04 PM
Re: Sky Q
Message posted on 15 Oct 2023 10:14 AM
Re: Sky Q
I have the same problem but it keeps going wrong again
