10
Discussion topic: Sky Q
This message was authored by Liise This message was authored by: Liise
Sky Q
I had the error message unable to connect to the satellite signal so I followed the instructions to reset but when I got to the part where it says to press the house nothing happens. I then checked the remote control as it said by pressing the ? And the red light came on so then I pressed ? and standby as the instructions said and still nothing. The tv will not reset   I was without my internet for a whole week and now this has happened and I have no TV. I am disabled and suffer with mental health issues I live by myself I have no one to help me   I can't get through to speak to someone please can someone help me
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Sky Q
@Liise wrote:
I've tried to but it keeps sending me round in circles
Hi @Liise
You need to check your LNB setting.
You do this in the hidden menu.
In Setup in the hidden menu you see LNB type.
Scroll right and you have the Option to set Wideband or SCR.
You need SCR
After changing the LNB type to SCR you need to reboot the Q box.
This message was authored by JordanBGoblin This message was authored by: JordanBGoblin
Re: Sky Q
Book an engineer by yourself from sky.com or the My Sky app.
Repairing TV, broadband and computer devices from 20 years in the UK, Czech Republic, Eastern Europe.
Re: Sky Q
Hi @Liise
Edit
If you carried out a Reset Settings this will have disconnected the remote from the Q box.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Liise
Re: Sky Q
The remote is now working but the SkyQ still won't reset it's saying you need a satellite signal to watch this tv
Re: Sky Q
hi @Liise
Do you have your own dish or are you fed by a communal System ?
Liise
Re: Sky Q
Communal system but no one else has a problem
Liise
Re: Sky Q
Re: Sky Q
hi @Liise
In which case you may need to check/set  the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down (switch off at mains or unplug)  your SKY Q box and restart it for the change to come into effect
Re: Sky Q
Hi @Liise
You need SCR
Liise
Re: Sky Q
Thank you @nigea99  & @oldfella
I have TV 🙂
This message was authored by Iandavies This message was authored by: Iandavies
Re: Sky Q
I have the same problem but it keeps going wrong again
