Discussion topic: Sky Q wont connect to Sky Router
Message posted on 28 Oct 2024 11:11 AM
An ideas? My main Sky Q box wont connect to my Sky Router, wont find it using WPS and if I try and connect manually by finding the router and putting the password in it says wrong password? Driving me nuts! Was working and now isnt and wont
Message posted on 28 Oct 2024 11:28 AM
Re: Sky Q wont connect to Sky Router
Hi @Max56
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 28 Oct 2024 12:06 PM
Sky Q mini box showing no signal
Message posted on 28 Oct 2024 01:18 PM
Thank you I have tried that and still nothing
