Discussion topic: Sky Q won’t connect to my Sky router
This message was authored by: Melg75
My sky q has stopped connecting to my sky router and won't re connect even after trying a reset and also trying to connect using the password.
Re: Sky Q won’t connect to my Sky router
@Melg75 do you mean you have rest your router or just the box ?
If just the box try rebooting your router by pressing the reset button on the back for 20 seconds then when that is up and running try reconnecting your Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
