3
This discussion topic has been answered Discussion topic: Sky Q won't connect to internet
This message was authored by: casnic
My sky q box won't connect. I've tried turning it off at the wall. I've pressed to was button, nothing is working
Avatar for casnic
This message was authored by: casnic Answer
Re: Sky Q won't connect to internet
I've contacted Sky, they said there is a problem with my SKY Q box, so are sending me a new one.  Thanks for the help.
Try turning off both your Sky Q box and your broadband router. See if they reconnect once they're both turned back on.
Hi @casnic
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for casnic
