Discussion topic: Sky Q with Samsung Frame
Message posted on 23 Oct 2024 01:48 PM
Hi
I have the Samsung Frame wall mounted above our fireplace. We have built the chimney breast out to create a niche behind the tv where the connect box and sky q box sit.
when the tv is off the wall sky works fine. Once I put the tv in place flush against the chimney breast, my remote won't communicate with the sky box and it just doesn't work.
Sky are telling me the box needs to be visible but surely not? What are my options?
Thanks in advance
Message posted on 23 Oct 2024 02:03 PM
Re: Sky Q with Samsung Frame
I suspect the housing for the Q box is effectvely blocking the remote's bluetooth signal. An infra red repeater might be a solution.
Message posted on 23 Oct 2024 02:08 PM
hi @LH70
Are you sure that the remote is paired with box ?
Until it is paired it works in IR mode
May I suggest you try a reset of your remote: & pair
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Once it is paired in bluetooth mode you should be able to control the box.
I have used my remote as a test from my back garden with my box in an alcove by my front window - so through 2 walls & 2 rooms
Message posted on 23 Oct 2024 02:11 PM
Hi
the remote is definitely paired as when I take the tv off the wall the remote works perfectly fine. When I put the tv back on the wall there's no signal and I can't operate the remote.
Message posted on 23 Oct 2024 02:12 PM
@LH70 wrote:
Hi
Can you use voice control OK ?
Message posted on 23 Oct 2024 02:13 PM
Yes I think this is definitely what is happening.
how does an infa red repeater work? Would this attach by hdmi to the sky box? And where would I get one from?
thanks
Message posted on 23 Oct 2024 02:14 PM
I've not tried this yet!!
Message posted on 23 Oct 2024 02:16 PM
Assuming you try when normal commands are working - then i voice control works then it is paired in bluetooth mode
If Voice control fails then it is possible it is not paired in bluetooth mode & relying on IR only
Message posted on 23 Oct 2024 02:40 PM
If you have to resort to one, there's a small receiver which you place somewhere convenient in the room, maybe at the bottom of the TV, connected by a thin cable to a sender which you'd place behind the TV where your Sky box can 'see' it. It will only repeat infra red commands, though, not voice control which is via BT.
Message posted on 24 Oct 2024 09:42 AM
I got it all working . . . Thank you so much for your help :lia_slightly-smiling-face: the control wasn't activated for Bluetooth!! Who knew :-0
