Discussion topic: Sky Q wifi dropping out
Message posted on 16 Feb 2024 07:13 PM
My Sky Q box keeps loosing wifi signal (wifi is working fine on everything else)
and mini boxes won't connect either. Only started happening today.
Anybody else having problems??
Tried resting numerous times, comes on for 30 seconds at most then lost again!!!
Message posted on 16 Feb 2024 07:24 PM - last edited: 16 Feb 2024 07:25 PM
Re: Sky Q wifi dropping out
Hi @Graham0705
Are you carrying out a Network Reset found in main Q box Home - Settings - Setup - Network.
Message posted on 16 Feb 2024 07:35 PM
Did that repeatedly, same outcome
Message posted on 16 Feb 2024 07:46 PM
Hi @Graham0705
Did you try rebooting your Router before you carried out the Network reset on the Q box?
If it's a Sky Q router also try pressing the reset button.
Hold Reset on the back of your hub until the power light flashes green (about 10 seconds). Don't unplug or switch off your hub while it resets. The power light will go green when it's done.
Wait until the router is completely back up and running before Carrying out the Network reset on the Q box
Message posted on 16 Feb 2024 08:07 PM
I have a eero router
Message posted on 16 Feb 2024 08:21 PM
Reboot it then @Graham0705
And then when it is completely back and running carry out the Network reset again.
Assume you are putting in the SSID and password for the router 2.4 Ghz band.
Message posted on 16 Feb 2024 08:23 PM
Thanks mate, I'll give it a go 🤞🏼
Message posted on 17 Feb 2024 10:55 AM
I now have WiFi signal everywhere but the mini box is connecting to the main box then dropping out (no picture), is there a way to boost the signal from the main box to push it to the furthest mini box?
Message posted on 17 Feb 2024 10:58 AM
Hi @Graham0705
That would be a Sky Q WiFi booster positioned halfway between Q box and mini.
Message posted on 17 Feb 2024 11:01 AM
Does this boost the picture signal, as my WiFi signal is over 100
Message posted on 17 Feb 2024 11:04 AM - last edited: 17 Feb 2024 11:07 AM
Hi @Graham0705
It increases the range of the WiFi which is what you said you need.
Edit ie
A WiFi booster is a device that extends your WiFi signal across your home. This is great if you have areas within your home which have a weaker signal. To extend your signal, a booster is placed in between a 'dead zone' (an area with weak signal) and the main Q box
Message posted on 17 Feb 2024 11:47 AM
My wifi signal is good now, just struggling with the picture
Message posted on 17 Feb 2024 12:50 PM
@Graham0705 wrote:My wifi signal is good now, just struggling with the picture
It doesn't use your wifi if you're not on sky broadband. It connects direct to a wifi network generated by the Q box.
