Discussion topic: Sky Q wifi connectivity
Message posted on 20 Aug 2024 07:58 PM
Every 10-15 mins the Sky Q. Box loses wifi connectivity
the sky q bix was replaced 10 days ago
EE been and confirmed their finre download and upload speeds are fine
yoir do a reset
10 mins later connectivity drops again
Message posted on 20 Aug 2024 08:02 PM - last edited: 20 Aug 2024 08:02 PM
Re: Sky Q wifi connectivity
yoir do a reset
Hi @SnoooTwo
Assume you are connecting your Q box as follows.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 20 Aug 2024 08:06 PM
We have done all that
spoke to Sky at the weekend and they talked me through that process
Message posted on 20 Aug 2024 08:09 PM
Message posted on 20 Aug 2024 08:13 PM
It's not practical to hard wire even though the router is less than 6 meters from the q box
what are the power line boosters and what will they do?
Message posted on 20 Aug 2024 08:19 PM
They are not Boosters @SnoooTwo
They allow an Ethernet connection using your Mains wiring.
You have one unit in a socket at and Ethernet connected to your router by Ethernet and one in a socket near near your main box connected by Ethernet.
Message posted on 20 Aug 2024 08:21 PM
If you wire from hub to main q box can you still connect mini boxes wirelessly ?
Message posted on 20 Aug 2024 08:26 PM
