6
This discussion topic has been answered Discussion topic: Sky Q box won't turn off.
This message was authored by: angiequo
Suddenly this morning my Sky Q box refuses to turn off.  It stays on amber.  I have unplugged it for over four minutes as advised, twice, and it works fine when it restarts, but it still refuses to turn off.  I've even changed the batteries.  If I hold down the off button then the TV turns off.
What on earth have I done to it?  And is there a way to correct it.  Any help would be much appreciated.
Re: Sky Q box won't turn off.
If the LED onthe front right of the Q box is Amber @angiequo   then it is off.
If the box was on it would be Green.
However regardless
However regardless
Sounds like it could be stuck in standby.
Try the recovery procedure as described in step 2 here:
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Avatar for angiequo
Thank you @oldfella , yes of course, it is stuck on green.  My error.  I'm all of a dither, sorry.
But now I have a blue screen saying Remote Control setup, and the please wait is hanging, and hanging.  What should I do now?
Hi @angiequo
Reboot the Q box.
Then
With the Q box on with green led try completly resetting your Bluetooth remote again.
Avatar for angiequo
@oldfellathank you.
I turned it off, it worked.  Then I turned it off, and on again.  It worked.  I'm going to leave it there while I'm ahead.  I will keep your instructions in case it happens again.  You are a life saver.  Thank you.
Avatar for angiequo
@lettice  its all sorted now.  Thank you.
