Discussion topic: Sky Q wifi connection keeps dropping
Message posted on 06 Apr 2026 04:44 PM
Message posted on 07 Apr 2026 08:55 AM
Re: Sky Q wifi connection keeps dropping
Hi there @Robdav371, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 15 May 2026 06:26 PM
I'm also having this problem - I've tried everything, from changing the channels on my wifi router, to rebooting my Sky Q box, to rebooting my wifi & Sky Q box, and all that seems to happen is that it'll keep connection for a few hours, but then at some point, it'll disconnect, & I don't know why. Is there any chance that I could talk to someone to help get it resolved?
Message posted on 15 May 2026 06:39 PM
Probably worth adding that it only seems to have happened since I've upgraded my broadband to fibre broadband (but kept the same provider - Zen Internet). I never had this trouble with my previous broadband connection, but it's immensely frustrating not being able to use the built in apps without having to re-enter my broadband password every time. It's a LOT of money to pay for a service which is more unstable than stable.
Message posted on 16 May 2026 02:32 AM
And I've now even tried splitting out the 2.4 & 5 GHz signals on my router, & just connected my Sky Q box to the 2.4GHz connection, & it's still gone off - and has even gone off whilst I was typing this.
Someone needs to help me sort this, otherwise, I will have to seriously consider ending my contract with Sky (we've been with them for over 20 years) & look to find another TV provider.
Message posted on 16 May 2026 09:05 AM
@jacobsladder71 wrote:And I've now even tried splitting out the 2.4 & 5 GHz signals on my router, & just connected my Sky Q box to the 2.4GHz connection, & it's still gone off - and has even gone off whilst I was typing this.
We're only other customers here so threats to leave will have no impact but try the following (The Zen box tries to 'band steer' all devices which the Q box doesn't like):-
Hardwiring the two together is preferred if possible.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
Message posted on 16 May 2026 05:37 PM
No, that didn't work. That was one of the first things that I tried when Googling how to rectify the constant drop-out. And my router is in a different room to where my Sky Q box is, so I can't use an ethernet cable to try a wired connection either.
Message posted on 16 May 2026 05:55 PM
I suspect my last viable option is to get an extender from Zen, & connect that via an ethernet cable to my Sky Q box. If that doesn't work, then... really not sure.
