05 Sep 2024 01:42 PM
Had BT and Sky Q box with no problems for years! Got convinced to have an EE router as it was cheaper and since then I've had five skyboxes two engineers and I'm on a pass the Buck merry-go-round.
I'm at my wits end with it all!! Please Sky can you advise and yes I have updated all my equipment via sky help.
05 Sep 2024 09:31 PM
Is there a fix for this. I have recently swapped from BT bb to EE bb and since then I am constantly having to try and reconnect my Sky Q mini boxes. At least on a daily basis? I have never had an issue when I was with BT but ever since the swap it is constant.
05 Sep 2024 09:37 PM
Hi
we are struggling with this problem.
Common factors are
• Using EE Fibre Hub.
• Connection via Ethernet
but not in all cases for the Ethernet.
I was also with BT. Swapped to EE on their recommendation. Had 5 new boxes before I started with others to raise it as an issue.
I had main box and 4 minis all connected to router via Ethernet with BT for 3 years. Super fast and never missed a beat.
Cant get 3 hours now with the EE one without it crashing, boxes are unresponsive and only a power reset will work. Again will crash very soon afterwards.
Will run ok ish on WiFi but why should I?
Any updates @Daniel-F
05 Sep 2024 09:42 PM
Mines connected via WiFi and I just can't get it to keep connection to the main box. It's so frustrating!!
06 Sep 2024 11:16 AM
Posted by a Sky employeeHi all,
As teams continue to investigate this we require more examples from users to help build a better picture of what you are seeing.
If you are are still seeing this issue please provide us with any fresh examples you experience. This includes if you have reported this before.
We are looking for:
Thanks,
06 Sep 2024 06:48 PM
@Daniel-F
the router I have is a smart hub plus
My devices are currently connected via WiFi
I use EE WiFi boosters but no other network boosting features
I have a Sky Q 2TB box the hardware version. Is 32D00D running software version Q270.000.10.02L(5u193hm)
I don't experience the whirring noise however I cannot connect either of my 2 boxes to the main Sky Q box. It starts with a loss of internet connection then I connect it to the WiFi then it loses connection to the box I reactivate and then will lose the connection to the WiFi again. Sometimes for some reason it will eventually reconnect after repeatedly reactivating both the connection to Sky Q box and connection to router. Sometimes I can be without sky for over 12hrs.
It will display no satellite signal on the mini boxes or sometimes an error code which is MR104. The Sky Q box and mini boxes are in the same locations as they were when I was with BT broadband and they worked perfectly. All other streaming services work uninterrupted through my TV such as Netflix and Prime the issue does seem to be affecting Sky only.
08 Sep 2024 06:16 PM
Hi Daniel, thank you for getting back to us on this most annoying issue.
1) ee: smart hub SH31
2) earthnet cable
3) Sky hard ware - 32B106
4) Sky software - Q270.000.10.02L(5u193hm)
5)Froze today 8/9/24 at 17.43. The Picture froze on screen and the noise was a loud whirring nose and you cannot navigate the screen. You can also hear the fan whirring on the sky q. Not using any other router other than ee.
please send help
Peter Martin
11 Sep 2024 06:36 PM
Hi @Daniel-F ,
Please find full information, including a daily log of the issues arising. Please let me know if anything else is required, I will paste this full information when replying.
Regards
Recent crashes
31/08/2024 - 15:43
01/09/2024 - 10:00, 20:45, 23:28
02/09/2024 - 01:43
03/09/2024 - None
04/09/2024 - None
05/09/2024 - 14:59, 18:00
06/09/2024 - None
07/09/2024 - 12:55
08/09/2024 - None
09/09/2024 - 09:55, 14:23
10/09/2024 - None
11/09/2024 - 18:05
Points to note
12 Sep 2024 12:32 PM
I have now noticed the whirring noise from our box and agree the box is completely inoperable. Whilst after turning off I eventually get sky service back it's so annoying to have to do full resets on all the devices usually twice daily.
12 Sep 2024 02:11 PM
Hi Daniel
Any updates on the problems we are all having? My Sky is now crashing 2 to 3 times a day!
kind regards
Peter
20 Sep 2024 04:51 PM
Hi @Daniel-F ,
Further crash information for you.
Regards
Recent crashes
31/08/2024 - 15:43
02/09/2024 - 01:43
03/09/2024 - None
04/09/2024 - None
06/09/2024 - None
07/09/2024 - 12:55
08/09/2024 - None
10/09/2024 - None
11/09/2024 - 18:05
12/09/2024 - pre-06:00
13/09/2024 - 14:06
14/09/2024 - None
15/08/2024 - 13:23, 16:02, 22:48
16/09/2024 - overnight
17/09/2024 - 12:00, 15:28, 16:32
18/09/2024 - overnight
19/09/3024 - 14:38
20/09/2024 - 12:28, 16:46
Points to note
20 Sep 2024 06:15 PM
Just as an update to this I seem to have found a sort of sticking plaster that seems to make the process easier. This seems to happen after a long period of no use, ie over night so it works when we watch TV in bed but when we get up in the morning the connection has gone. Usually the main box has gone into a sleep mode (power light on main box is red). I have found that by turning the main box on and allowing that to power up before I use a mini box all I generally have to do if anything at all is reconnect the mini box to the main and it pretty much works every time I have been doing this for about a week now. I know this only seems to work for my fault but maybe worth others trying to try and narrow down where the fault lies as Sky can't seem to find anything?
22 Sep 2024 05:09 PM
Scrap that today the box will
not stay connected at all it reconnects and then disconnects straight away. All other devices in the house connected to the internet work fine it's just the sky.
@Daniel-F do we please have an update for this? This is getting ridiculous I pay a huge amount to sky every month to not watch TV!
22 Sep 2024 08:27 PM
When will someone from Sky respond to these messages? My Sky has already frozen 4 times today! I'm going to contact Sky tomorrow and if I don't get any results my the end of the week then I'm leaving, I've been with Sky over 20years!!! SKY PLEASE HELP!!!
22 Sep 2024 09:14 PM
I have decided the same. No matter what I do my sky box will not recognise my we router. So my box and mini box are pretty useless. I am leaving at the end of the month to have EE tv installed before the Christmas films start.
