Discussion topic: Sky Q box crashing & box fan spinning loudly - EE Broadband
Message posted on 02 Jul 2024 11:48 AM - last edited: 17 Oct 2024 04:15 PM
Hi all,
I've made this thread to collate / tidy a few other threads where I've noted users have specifically mentioned being with EE Broadband and their Sky Q equipment have been making loud fan noises or freezing overnight.
Moderator note: Updated thread to better reflect query
Community Moderator
Message posted on 09 Sep 2025 04:17 PM - last edited: 09 Sep 2025 04:28 PM
Hi all,
We reached out to EE for support on this as users here have identified a common ground with the ethernet stability of EEs Smart Hub Plus routers.
We can confirm there are no known issues with EE routers and Sky Q but please refer to this thread on the EE Community regarding an update to the hub power supply: https://community.ee.co.uk/t5/Broadband-Landline/EE-Sending-out-Replacement-Power-Supplies-for-its-…
For support on your replacement equipment please contact EE directly.
I'll conclude this thread for now, but if you need any further support on your Sky equipment please feel free to come back to the Sky Community.
Message posted on 07 May 2024 04:11 PM
My sky Q BOX KEEPS DISCONNECTING FROM MY EE BROADBAND
My sky q box keeps disconnecting from my EE BROADBAND
Message posted on 07 May 2024 04:16 PM
Re: My sky Q BOX KEEPS DISCONNECTING FROM MY EE BROADBAND
@Popmac Is it the main Q box? Have you tried rebooting it? Is it connected over WiFi or with an ethernet cable?
Message posted on 09 May 2024 08:06 AM
It is the main box and wifi
Message posted on 12 May 2024 10:09 PM
I am having f the same issue it's driving me insane ! Had EE engineer up who said all WiFi is working fine ! If I hard wire an Ethernet and runs my WiFi off my mini boxes won't work ? Any ideas ?
Message posted on 12 Jun 2024 11:33 PM
Re: My replacement SKY Q box crashing and whirring overnight
Wow, yes that's exactly the same issue. 7 boxes! omg.
It does seem really bizarre. Before my previous box failed i had just switched broadband provider from BT to EE. So i had to set up the latest new EE router. Desperate for an answer I was even wondering if that change of broadband caused the issue! NB - My sky box has a wired ethernet connection. But yesterday I did reset /set up the network connection - trying wifi and then returning to a wired ethernet connection. (as it's over twice as fast)
Amazingly after 4 crashes/freezes and restarts on monday/tuesday. It hasn't happened since ( probably tempted fate now) 🙄 🤔
Message posted on 13 Jun 2024 12:01 AM
Thanks for the advice - I am in exactly the same situation.
Changed from BT to EE and their new router a few weeks ago (same provider really - think EE is their new domestic user label).
Will give it a go tomorrow and feedback.
Message posted on 13 Jun 2024 12:37 AM
Can I ask which broadband provider you are with ? You may see from replies in this thread that my issues started after i switched to EE and set up their latest router. One other user on here also switched to EE with the same issues. It's probably coincidence but worth asking. Simon
Message posted on 13 Jun 2024 05:11 AM
We had a sky member on the phone who assured us she had fixed it yesterday, but after 10 mins the same thing happened.
That's really interesting as it's happened when we swapped from bt to EE.
How have they not notcied the pattern?
Message posted on 13 Jun 2024 05:31 AM - last edited: 13 Jun 2024 05:32 AM
@Niknok84 wrote:We had a sky member on the phone who assured us she had fixed it yesterday, but after 10 mins the same thing happened.
Well, 3 people (that's how many have confirmed in here, and there were at least another 3 who haven't said either way) out of hundreds of calls a day doesn't make much of a pattern but it's either a coincidence or a bit of a smoking gun.
I would try a different router (I assume EE still let you use whatever router you want, BT always did) and see if the problem stops. Or maybe try ethernet cable for a while if possible and disable wifi and see if it stops?
edit: or I suppose an even easier test - just disconnect it from the internet completely and see if it stops.
Message posted on 13 Jun 2024 08:00 AM
It is interesting regards EE - will have to see how this plays out. Alas having had a day yesterday with no crashes - this morning i found my box has crashed overnight again - while on standby - the louder whirring sound and non responsive box needing a power off to reset. 😞
Message posted on 13 Jun 2024 08:21 AM
@Popmac did you get this resolved? i am having regular problems with My new EE broadband which appears to be causing regular crashes of sky q box needing power off resets. There are other posts where quite a few people are suffering similar issues who are with EE
Message posted on 13 Jun 2024 11:35 AM
Have spoken for some time with EE tech support. They have run all sorts of diagnostics checks and everything is working well and as it should. They say they are not aware of any issues of EE broadband causing issues with Sky Q boxes. They say it is a Sky issue and everything else is working normally on broadband/wifi - which is a fair point. So will have to wait for the Sky engineer next week.
Message posted on 13 Jun 2024 11:40 AM
Thanks for the update. I will get back in touch with Sky.
FYI I have the latest EE broadband hub with a wired connection to the Sky Q box.
All the boxes I have received to date have been the V2 variant - with the silver trim.
My original Sky Q box was V3 all black one - it had no issues with the EE hub - the harddrive failed.
Message posted on 13 Jun 2024 11:41 AM
@Greenfingers001 please see the updates on this thread, can you pass on to someone in sky to look at this common and infuriating issue that appears linked to customers who have just set up broadband with EE.
If Sky are sending engineers to all these people affected or sending out as many new Sky Q boxes as described then that must be costing Sky a lot of time and effort and money!
So it's worth investigating these issues collectively to work up a solution.
Hope you can help.
Simon
