Discussion topic: Sky Q very slow, not showing pics on recordings and intermittent black outs watching some channels
Message posted on 01 Jan 2026 10:56 AM
Sky Q box very slow from turn on, then when changing channels.
No pictures coming through when switching between channels, recordings, catch up and Apps
Intermitant picture drop out - black screen
Been like this since before Christmas and have tried all the recommended 'fixes' as per the Sky website
Message posted on 01 Jan 2026 11:46 AM
Re: Sky Q very slow, not showing pics on recordings and intermittent black outs watching some channe
Hi @PeterD121
Message posted on 01 Jan 2026 12:19 PM
Already done all that - no joy
Thanks for the response though
