This discussion topic has been answered Discussion topic: Sky Q to mini via ethernet stopped working.
Message posted on 13 Nov 2025 06:33 PM
Hi our sky mini is connected to sky Q box via ethernet as the distance for wifi was too far. Been installed for over a year no problems.
yesterday our internet went down so i turned hub off for the night as was just flashing not connected.
today the mini wont work. Says connection to hub lost but its only ever been done via ethernet to skyQ box. We have a dish so can watch tv through sky Q box no problem just not on mini box tv.
i have turned off boxes, put back on etc with no luck. Settings on the mini doesn't say anything about wired connection.
everything i have read says no internet shouldn't make a difference if boxes are connected by Ethernet.
what has gone wrong???
thank you
Message posted on 14 Nov 2025 07:10 PM
@lorri66 wrote:
Didn't need to do anything in the end as when I went to try and sort all armed with instructions turned it on and low and behold it was working!!!
thank you for all your help though.
Glad it is now working OK for you
Message posted on 13 Nov 2025 07:17 PM
Re: Sky Q to mini via ethernet stopped working.
today the mini wont work. Says connection to hub lost but its only ever been done via ethernet to skyQ box. We have a dish so can watch tv through sky Q box no problem just not on mini box tv.i have turned off boxes, put back on etc with no luck. Settings on the mini doesn't say anything about wired connection.
thank you
hi @lorri66
Is the hub now back on and the main box connected to it ?
The hub does not need to be connected to the internet but the hub must be on & the main box connected to it as it provides the ip addresses needed for the mini box & main box to communicate with each other
Message posted on 13 Nov 2025 07:50 PM
Hub is on but flashing orange (plusnet hub) as no internet/broadband i guess. Hopefully fixing by openreach in next few days.
our speeds were less than 1 !
but i guess i didn't think this was needed if we have a dish & ethernet connection from Q box to mini.
Message posted on 13 Nov 2025 07:55 PM
hi @lorri66
As I mentioned you shouldn't need the internet but you do need an active network
Is the main box connected to it OK (even though the internet is not availble/flakey) ?
Either way I suggest you try rebooting the router and then the main box, followed by the mini
Message posted on 13 Nov 2025 08:22 PM
Ok will check later
but what if i try to connect and it says no internet?
Message posted on 13 Nov 2025 08:25 PM - last edited: 13 Nov 2025 08:26 PM
Message posted on 13 Nov 2025 08:30 PM
It says connected to broadband router but no internet connection.
Message posted on 13 Nov 2025 08:32 PM
Message posted on 13 Nov 2025 08:33 PM
Asks if i want to connect/retry but i know ot wont as dont have any broadband at the moment.
Message posted on 13 Nov 2025 08:35 PM
It wont though thats the issue.
says about no connection to hub but its nvr connected to the hub as far as i was aware as its wired to Qbox.
Message posted on 13 Nov 2025 08:37 PM
hi @lorri66
the mini box does not connect directly but it connects via your Main box to the hub
Did you manage to restart everything or is that pending ?
Message posted on 13 Nov 2025 08:50 PM
Hi @lorri66
When Mini boxes are connected by Ethernet you can then switch off all mini box WiFi.
carry out a Network reset on the mini with the Ethernet connected.
Network Reset found in box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side.
Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go immediately into the mini box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Message posted on 13 Nov 2025 08:53 PM
Pending!
as football & tennis is on so dont want to risk losing any of that on main box.
i had reatarted earlier & turned both boxes off at socket before putting post on here.
Message posted on 13 Nov 2025 08:57 PM
Ah ok i will have to do this mayb tomorrow. Settings just normally takes me to wifi stuff so i will try the 001
Message posted on 13 Nov 2025 09:19 PM
