Discussion topic: Sky Q sounding like squabbling ducks
This message was authored by: Braithwaite
Had Sky Q for 3 months.
About four or five times now the sound quality is impossible to understand. The picture remains fine. Never had this problem before I supposedly upgraded to Sky Q.
Is this a common problem and what is the best way to solve it
Re: Sky Q sounding like squabbling ducks
Not reported here that I recall.
Log the issue with Sky: they'll probably want to swap out the main Q box.
Hi @Braithwaite
Try a Reset Settings in the Q box hidden menu.   See if that helps
