Discussion topic: Have WiFi, but no connection to sky box
Message posted on 18 Jun 2023 09:44 AM
Message posted on 18 Jun 2023 09:50 AM
Re: Have WiFi, but no connection to sky box
@Boss+lady+2019 Is this Sky Q or Sky + that you are trying to get this re-connected?
Message posted on 18 Jun 2023 09:51 AM
Sky Q
Message posted on 19 Jun 2023 12:29 PM
@Boss+lady+2019 wrote:
I have wifi/Internet on all my devices, except from my sky boxes. I've reset the router and followed all the advise on sky to get it all restarted, but nothing works. It's been like this for 4 days! Getting rather frustrated now. Never use to have this problem
Assume you have tried a Network Reset on your main Q box found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 19 Jun 2023 12:33 PM
Hi
Yeah I've done all that. Got an engineer coming this week 😊
