Discussion topic: Sky Q replacement
This message was authored by: Diydel
Sky Q replacement
Hi
My Sky Q is failing frequently , recordings show as no longer available or the system freezes necessitating unplugging and restarting.
I've also had to reset the hard drive to get it working on several occasions obviously loosing all recordings.
I need to get a replacement but seems impossible to find who can arrange this, bearing in mind it's their equipment not mine surely they should fix/replace?
Re: Sky Q replacement
@Diydel
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
HAPPY NEW YEAR
