7
This discussion topic has been answered Discussion topic: Sky Q remote
This message was authored by: David8484
Sky Q remote
Good evening, where in the sky Q remote / TV is the ability to search 24 hrs ahead like before. Using the coloured buttons. Thanks in advance.
This message was authored by: Laing1 Answer
Re: Sky Q remote
@David8484 use the fast forward button each press will  go 24 hours ahead up to 7 days and the rewind button to go 24 hours back only to the current day and time  the play button will take you straight back to the current day and time
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sky Q remote
Re: Sky Q remote
Detailed in this community tips and tricks article;
https://helpforum.sky.com/t5/Sky-TV/How-do-I-jump-forward-a-day-in-the-TV-guide-on-Sky-Q/ba-p/287574...
Avatar for David8484
Re: Sky Q remote
Ahh you used to be able to press the yellow button and go 24hrs plus at a time.
Re: Sky Q remote
@David8484 yes Q is soo different to HD+ 😀
Re: Sky Q remote
Thanks 🤩
Re: Sky Q remote
@David8484 wrote:
Thanks 🤩
@David8484 your welcome if there is anything else just post again we are a friendly bunch here 😁
Re: Sky Q remote
Brilliant. Finger trouble. Sorted now 👍👍
