Discussion topic: Box sets not working
This message was authored by: ANDREW338
Since moving home box sets are not available
Re: Box sets not working
@ANDREW338 silly question but can you confirm you are connected to the internet and your Q box is showing as being connected
if you are then
Have you tried rebooting your main Q box ie
are you getting any error messages
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
