3
This discussion topic has been answered Discussion topic: Sky Q remote volume not working
This message was authored by: aferns
My Sky Q remote volume is not working.  Everything else on the Sky Q remote works.  Any ideas?
Re: Sky Q remote volume not working
Looks like it is not correctly paired to the television @aferns
Avatar for aferns
Level 3 icon
Thank you that worked 🙂
This message was authored by: Janeyc1
Thank you worked perfectly
